Router connected but speeds from 0-12mbps
Justaskin2
Message 28 of 28
Here's my issue. After a stormy night my broadband connection is terrible. Although the hub light remains white at all times, the speed varies between zero and around 12mbps. It hits zero around every 5-10 minutes or so. At that time any connected device reports no internet signal. If im streaming ITVX or iPlayer they just go into a permanent buffer or black screen. When the speed increases they start up again. Also my phone line is super crackly.
My normal speed is 20mbps and is rock solid.
I am using a Deco mesh system and the TT routers wifi is disabled. (I have tried disconnecting the mesh and using the router wifi but no change.) The complete system has been working flawlessly since I joined in November.
Run the line test which showed no fault. Went on chat. He ignored my repeated cry that it was not a wifi problem, but a line problem and they run through all the items on the list in front of them concluding with the agent resetting my router which he claimed had solved the problem and closed the case.
I have tried running another line test and get told I cant as there is an open case yet my dashboard shows case closed.
Who can I contact to speak to as I cant get to report the fault again.
Talk about frustrating.
27 REPLIES 27
Message 21 of 28
Yes, I understand that, I am just trying to save you time if the fault is not on the line. It is the standard demarcation point between the TalkTalk network & what is your responsibility. Just undo the two screws on the lower front section & gently pull it out (there may be wires attached behind it). The test socket is behind that, because the faceplate is prefiltered, you must now use a microfilter to prove where the problem lies.
Message 22 of 28
Thank you for replying. Not sure about socket. It's an open reach mk4 master socket 5C. it's got 2 plugs one with a picture of a phone and the other a picture of a router. Not using an additional micro filter. Its all exactly as the open reach engineer left it on installation.
My issue today is actually getting through to any support as the computer says no as I have an open case ( but I have not)
Message 23 of 28
Have you tried moving the router with a new microfilter to the test socket behind the master socket's removable faceplate (if you have that design). If it is no better, then you have no option but to contact the Service Centre or wait for the support team on the Community to investigate this on Monday.
Justaskin2
Message 24 of 28
Blinkin internet is disrupting my efforts to reply!!
Just found minimum guaranteed speed 18 - max 22
Message 25 of 28
Yes using the TT router. Dashboard shows speed as between 9 and 12 mbps
I cant remember the speed they promised, I believe it was 15 or 17 - rural area with overhead lines.
Justaskin2
Message 26 of 28
Message 27 of 28
I assume that you are using the Sagemcom FAST5364 router? If you log into it & look in the initial dashboard area, what does that show the internet speed as? What is your guaranteed minimum download speed?
