Router resetting itself constantly
melty
Message 15 of 15
My router is constantly resetting itself, the error log says it's due to 'kernal panic'. I've seen a few other people with the same issue have it resolved with a firmware update. How do I contact someone to help with my issue / update my firmware?
14 REPLIES 14
Message 1 of 15
Message 2 of 15
Thanks for your help
Message 3 of 15
I've started the update, it should complete in a few minutes, please don't switch off your router
Message 4 of 15
OK thanks. Yes, I'll udpate the firmware now
Message 5 of 15
Hi Chris,
No I still have the kernel panic resetting issue. I talked to tech support last week but they insisted on sending out open reach. They've just been, they did tweak something (line attenuation was a tiny bit high) but said it wouldn't cause the router to reset like it has been. And it's already reset since they've left.
Would you be able to update the firmware?
Message 6 of 15
Hi melty,
How are you getting on, are you still experiencing problems with your router?
Message 7 of 15
Thanks, have a great Christmas.
Message 8 of 15
Actually, I did this last night @melty
Message 9 of 15
Yes please that would be great.
Message 10 of 15
Alas, the TalkTalk staff on here would do it very quickly for you, but they are not back until Wednesday now. Do you want me to escalate this to them for when they return?
Message 11 of 15
I thought as much, i tried asking specifically but they just follow a script I guess.
Message 12 of 15
That is rubbish advice I am afraid, it is a well-known bug in the DG8041W firmware V1.05. It is the sole fix in V1.06. They should be able to upgrade it for you.
Message 13 of 15
Thanks Keith,
I have spent an hour on hold with the tech support but they are adamant an open reach engineer needs to come and check the line.
Message 14 of 15
I have asked one of TalkTalk's support to pick your thread up and update it for you.
