VDSL is down port 1
Scottydog13
Message 3 of 3
I am getting frequent disconnections on my line and the below is my log from my router, I have also noticed the sound margin is 0.00db!
DownstreamUpstream
6000017000
6304617000
0.006.00
16.100.00
13.106.60
26.12.2023 01:28:27InfoSYS
TR-069 connectivity to (acs.talktalk.co.uk) has been closed
26.12.2023 01:28:24InfoDHCPC
The WAN DHCP client IP address 2.101.103.204
26.12.2023 01:27:50InfoDHCPC
WAN DHCP client (1) started
26.12.2023 01:27:48InfoXDSL
VDSL connectivity is up port 1
26.12.2023 01:27:23WarningDHCPC
WAN DHCP client (1) stopped
26.12.2023 01:27:23InfoXDSL
VDSL connectivity is down port 1
Message 1 of 3
Good morning,
  • Account Number
Message 2 of 3
