DG8041W - DEVICE RESET CAUSE: SYSTEM RESET DUE TO KERNEL PANIC
jj8811
Message 10 of 10
Router and wifi keeps rebooting, checking the error logs there is multiple kernel panic messages
[Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
Manufacturer:Huawei Technologies Co., Ltd;
ProductClass:DG8041W;
HWVer:I.1.01;
SWVer:v1.05t;
Already phoned several times and the support could not diagnose the issue so have managed to work it out myself so please can someone update the firmware to the v1.06 or send a new router please
9 REPLIES 9
Message 1 of 10
OK, if you need any further assistance just let us know
jj8811
Message 2 of 10
Thanks seems to have done it fine
Message 3 of 10
I've started the update, it should complete in a few minutes
Message 4 of 10
Thanks, that seems to have done the trick so I'll update your firmware now. Please don't switch off your router
Message 5 of 10
It's been done please try again
Message 6 of 10
I'm experiencing some problems communicating with your router. Could you switch it off and leave it off for at least 30 minutes, then switch back on and let me know when you've done this
Message 7 of 10
Yes ok to update anytime thanks
Chris-TalkTalk
Message 8 of 10
Hi jj8811,
Is it OK to update your firmware now?
Message 9 of 10
I have asked one of TalkTalk's support to pick your thread up and upgrade it for you.
Anonymous User
