Router won't connect
nwilson992
Message 11 of 11
This morning my router won't connect. It just keeps flashing orange.
I tried plugging my laptop into the router via a ethernet cable, but that won't even load the router dashboard on the 192.168.1.1 address.
The talk talk login page doesn't load (currently using a phone hotspot).
I can't see any service status saying there's an issue, but your website won't load the login page.
The router is currently on. Can someone run a line test please?
Openreach was over the road yesterday, so hope they've not caused a problem when messing about with cables.
10 REPLIES 10
Message 1 of 11
Message 2 of 11
Message 3 of 11
Thank you!
Message 4 of 11
Hi @nwilson992
Message 5 of 11
If possible, yes please.
We've had this router for many, many years!
Message 6 of 11
Ok, would you like us to send a replacement router for testing purposes to rule this out?
Message 7 of 11
We have a Mastersocket 5C MK4.
I've taken the faceplate off and connected the router directly into it, but still no connection.
I've pushed the reset button on the router, and still no not.
I was unable to find the old router to test.
Message 8 of 11
Ok thanks for confirming and please let us know how you get on with the alternative router. Does your main socket also have a test socket?
nwilson992
Message 9 of 11
Thanks for the quick reply.
We don't have a phone/phoneline plugged in to try/test.
We may have an old router, I'll give that a try
Message 10 of 11
Thanks for your post and I'm sorry to hear this. I've run a test on the line now which is clear but the line is not showing in sync. Is the voice service ok and do you have a dial tone? Does your main socket have a test socket? Do you also have an alternative router that you could test with please?
