on 30-07-2024 09:54 PM
Hi, over the last couple of months the router (Sagemcom Fast 5364) has been getting progressively more and more unreliable - not saving settings, dropouts, needing regular rebooting, freezing when logged in to it, etc.
Over the last couple of weeks or so it seems to have broken completely. It now requires a factory reset every 24 hours to be able to access the internet.
How long will it take for a replacement to be sent out?
Thank you in advance
on 05-08-2024 08:54 AM
on 31-07-2024 07:11 AM
Morning @Olivia45
I've ordered you a replacement router, please allow 24-48hrs for this to arrive.
on 30-07-2024 10:10 PM
Alas, the problems with the UI are a bug in the firmware. Whilst I can help with the speeds, by the sound of it, the initial course of action is to replace the router, which will take a couple of days after TalkTalk dispatches it. I have asked one of TalkTalk's support to pick your thread up and replace it for you.
