Sagecom router keeps resetting wifi channels despite me having set them manually.
on 10-10-2024 11:37 AM
Message 6 of 6
My Sagecom router keeps resetting wifi channels despite me having set them manually to values that do not get swamped by stronger signals other routers near by.
This happened to me in January 2023 and somebody on the TalkTalk Community was able to swith off automatic optimisation on my router. Unfortunately, my router has recently died and had to be replaced with a new one and the channels are back to changing on at least a daily basis.
Please can channel optimisation be switched off on my new router.
Many thanks
Paul H
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
5 REPLIES 5
on 10-10-2024 01:15 PM
Message 1 of 6
The same would apply if you had done a factory default of the router's configuration at any time as well, which would reenable the optimisation.
I am not promising miracles and if needs be I can use the information you provide me with as evidence as to where WiFi Optimisation might be going wrong. Then there is a chance, but again no guarantees, that I might be able to get you an exemption.
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-10-2024 12:10 PM
Message 2 of 6
Thank you for your kind offer of help. Happy to give it a go if you can send me your guide.
However, I must say I am very sceptical as I never had any further issues after optimisation was switched off in January 2023 and I choose rarely used channels for both 2.4 and 5g. This has only become an issue again as the router died and had to be replaced.
Paul H
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-10-2024 11:57 AM
Message 3 of 6
So what can I do, there must be a solution? It is intolerable to have manually reset wifi channels once or more a day.
I suspect my neighbour might switch their router off at night. In these quieter times the Talk Talk router resets to the common 1, 6 or 11 and then when Sky routers come on line in the morning my signal get swamped. They only way to avoid this has been to monitor used WiFi Channels and choose one that is never used.
Please help as this is incredibly frustrating and after many calls to Tech Support in January 2023 you help via the Community was the only thing that kept me with Talk Talk
I am out of contract and this a matter I will go to another provider to cure.
Paul H
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-10-2024 11:49 AM
Message 4 of 6
The TalkTalk staff are no longer permitted to disable WiFi Optimisation anymore, which is a business decision. I have investigated a number of cases for TalkTalk where WiFi optimisation has been blamed for poor WiFi performance/coverage & recently I have found the cause to be something else. I must stress here that I am not a fan of WiFi Optimisation myself, but I know a lot of work is being done on the algorithm that it uses & hopefully, it will get much better in the near future.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-10-2024 11:47 AM
Message 5 of 6
Hi Paul,
I'm sorry but we no longer switch off wifi optimisation as this can cause other issues.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
