Interleaved
compu
Message 12 of 12
I few weeks back has some power failures on the powerstrip where my router is connected, as a result of this seem my line has switched to interleaved. I do not use the Talktalk Hub as this has started causing issues with real time music collaboration apps where noise is generated and with Interleaver switched on I now have a lot of jitter on the upload stream. Would it be possible to have this reset?
11 REPLIES 11
Message 1 of 12
Message 2 of 12
Yes, cancel it, there is no fault, still connected, Thanks
Message 3 of 12
Hi compu,
Looks as though the line test picked up a disconnections in the network, this resulted in a non-appointed engineer (just to check the line) to be arranged. If everything is working OK I can cancel the engineer, would you like me to do this?
compu
Message 4 of 12
It was all automatically arranged after I did the line test, I have only reported here since last night.
Message 5 of 12
Have you been in touch with our Tech Team directly to cancel this engineer? When has it been arranged for?
compu
Message 6 of 12
I had an issue tonight with the line not connecting I think caused by turning the router back on from a power strip and router would not connect, after this happened I run a line test and you advised there is a fault and booked a BT Openreach Engineer.
Please note that you might want to cancel it as I then waited around 45 minutes before turning the router back on again and is all working fine now. I think turning the router from the power strip might have caused a surge and router was unable to connect. Now all working.
Message 7 of 12
Hi compu
Usually we advise at least 48hrs for DLM to monitor and start making changes to the line profile.
Would it be possible to connect the TT router again to see if this helps?
We can't specifically request Openreach to change profiles to/from interleaved, Openreach will only reset DLM.
Message 8 of 12
Thanks Debbie, how long does the monitoring last? It has been 3 weeks and the usual interleaver dept of 4 - 1 is still on 16 - 1 since the power failure I mentioned earlier.
Message 9 of 12
HI @compu
I ran a line test just to make sure everything looked ok and no faults were detected.
As Michelle has advised, we are unable to change/choose profiles now, this is managed by DLM.
If you leave the router switched on then DLM will monitor the connection and choose the best profile for your line.
compu
Message 10 of 12
Thanks Michelle, I have now updated my info.
Message 11 of 12
Good morning,
I'm sorry for the delay. It's not possible for us to manually choose a profile but we can have a look at your connection stats for you.
  • Name
  • Telephone number
  • Alternative contact number
