Disconnections daily
adrian555155
Chat Champion
Message 29 of 29
Hi, after one and a half month of no disconnects I've started having issues again. Last time it was due to some phone line fault which you guys have fixed.
As of 17th May, my Internet disconnected once and I was put on interleaved, ever since its been disconnecting almost daily, sometimes twice a day, I was then recently put on the even more stable profile with higher latency and even slower speeds but it still proceeded to disconnect daily, TT status page said 'your broadband connection could be improved' and said that there was intermittent disconnects taking place.
Recently tried turning router off for over 30 minutes which didn't help. Then last Friday I connected to a test socket and left it there over the weekend, it's still connected to it, since then there have been no disconnects for two days, and service page says I've got a healthy connection. Dlm still not made my any changes though.
28 REPLIES 28
Message 1 of 29
this is the profile at this moment as reported via Openreach when testing. We have no immediate control over the profile and it may change however this cannot be guaranteed.
adrian555155
Chat Champion
Message 2 of 29
Historically it's come back to a faster profile as long as the line remains stable with no disconnects. Just over a month ago I was on fast path until disconnects started happening. I trust it will come back as there were no disconnects for 7 days. Also interleaving can't be low when I went from 18upload to 13up, 59 download speed to 50-53 and ping went from 6 to 23-26
Message 3 of 29
The profile itself is set at 80 Downstream / 20 upstream Interleaving Low, so DLM has set this as the best determined profile for the line so this may not change.
adrian555155
Chat Champion
Message 4 of 29
What do you mean, I'm not talking about the package, I know I'm on 80/20, I'm talking about the DLM profileike fast path and interleaved, I'm currently on the extra Interleaved profile, which has added 20ms latency, and reduced download and upload speed.
Message 5 of 29
The DLM profile is showing currently as 80/20 and has been set this way from 28th, so the profile is correct and cannot increase further.
adrian555155
Chat Champion
Message 6 of 29
Yeah that's good, sadly tho after 7 days of stability the DLM still not changed profiles, perhaps there are still many errors? Are you able to check error count?
Message 7 of 29
Thanks for trying this and I'm glad to hear that the throughput speed has improved.
adrian555155
Chat Champion
Message 8 of 29
Had the router turned for bit longer than 30 minutes, speed test shows 53.6 down 13.8 up.
Message 9 of 29
Hi adrian555155
The line is in sync at 56mb. Please can you try a 30 minute power down of the router (please only try this once) and then run a speed test?
adrian555155
Chat Champion
Message 10 of 29
Just ran a speed test, 45.51mbps down and 13.28mbps up.
The download speed is a one off though usually it is 50
Message 11 of 29
Hi adrian555155
What speed are you currently receiving?
adrian555155
Chat Champion
Message 12 of 29
No disconnections since, sadly still on the slow stable profile
Message 13 of 29
Hi adrian555155
How has the connection been since your last post? I can't see any re connections on the line.
Message 14 of 29
Hi adrian555155
Thank you. I will post back on this thread again on Friday.
Debbie 🙂
adrian555155
Chat Champion
Message 15 of 29
Yes that's okay thanks, hopefully it will remain stable. If it disconnects again I will try connecting again to test socket and leave it for longer than last time, as I would really want to rule out if that's a problem.
Message 16 of 29
Hi adrian555155
This may have been DLM adjusting the profile.
The connection has remained stable since this date. I will check the connection stats again on Friday to see if there are any further re connections, will this be ok?
adrian555155
Chat Champion
Message 17 of 29
Yes, first disconnect when I reconnected the faceplate and later that evening the Internet disconnected by itself.
Message 18 of 29
Hi adrian555155
The line test is not detecting any issues and your line is in sync at 56mb.
I can see 2 re connections on 02/06 was this when you re connected the faceplate?
adrian555155
Chat Champion
Message 19 of 29
Yes please
Message 20 of 29
Hi adrian555155
Would you like me to run a line test and check the connection logs?
