Sagecom router
raymundo2
Message 5 of 5
I would like to ask if I turn off 5gig connection on my sagecom router and disable band steering will this cause any problems with router I have had to get a new router twice  in the last year because it has gone faulty and lost total connection
I only want the 2.4 gig band owing to 15 devices I have that only work on this band and some require a greater distance than 5 gig offers There is no chance of interference on this band as I live in a sparsely populated area
Thanks for any help
4 REPLIES 4
raymundo2
Message 1 of 5
Thanks for help To all
Not very good at this so hope I have replied in right place
raymundo2
Message 2 of 5
Thankyou for help  Regards Raymundo
Chris-TalkTalk
Message 3 of 5
Hi raymundo,
As Divsec says, I can't see any issues either
Divsec
Message 4 of 5
Hi @raymundo2 I can't see any issues, you could also create a guest WiFi ssid and password on one or both channels.
