Sagemcom-FAST5364 power button sticking and randomly turning off
JasperLeFarge
Message 16 of 16
We've had the Sagemcom-FAST5364 router for quite a while.  We've noticed recently that the power button isn't working properly anymore - it takes a lot of tries and *just the right* angle to turn it back on when it's been switched off.  And as well as that, we've noticed it now just randomly turns off (not reboots - just switches off) for no reason.  We can only presume it's again the power button.
Does anyone have advice for us please?
15 REPLIES 15
Message 1 of 16
Hi JasperLeFarge
Thanks for returning the router.
I have switched the WIFI optimisation off as requested.
Thanks again.
Message 2 of 16
I've just realised I need WiFi optimisation switched off again please.
Old router on it's way back.
Message 3 of 16
Hi JasperLeFarge
Thanks for letting us know.
If everything is working ok then please can you return the old router using the pre paid returns bag within the next week.
Message 4 of 16
It seems to be working well so far. I can tell the difference with the power button.
How long do you suggest we leave it for fuller testing before we send the old one back?
Message 5 of 16
Just checking back in to see how you're getting on?
Thanks 🙂
Message 6 of 16
Hi JasperLeFarge
Ok no problem, please let us know how you get on.
Message 7 of 16
Yes it has arrived. Can’t test it until the weekend though.
Message 8 of 16
Hi JasperLeFarge
Message 9 of 16
Hi JasperLeFarge
Please let us know how the connection compares with this router.
Message 10 of 16
Yes please send a replacement.
Thank you.
Message 11 of 16
Hi JasperLeFarge
Just to confirm, would you like me to send a replacement router?
Message 12 of 16
@JasperLeFarge, staff will be back on Monday. Please check back then.
They are not on here at weekends.
JasperLeFarge
Message 13 of 16
Yes please we need help. It turned off again just overnight.
Message 14 of 16
Do you still need assistance with this?
Thanks 🙂
Message 15 of 16
Would you like us to send a replacement router for testing purposes? We would also send a router returns bag so that one of the routers can be returned.
