disable wifi optimisation request
bananarama1
Message 3 of 3
My sagem router has recently had a firmware update.
My router keeps auto changing channel even though I set it manually.
This is causing daily wifi issues.
I need the wifi channel manual function.
Please may an OCE fully disable the wifi optimisation on my line?
Thank you
Kind regards
Message 1 of 3
Hi bananarama1
The WIFI optimisation has been switched off.
Gliwmaeden2
Message 2 of 3
You will need to request this after firmware updates or whenever you reset the router (but not after simply switching it off then on), @bananarama1.
It's never permanent. Leave the router on for staff to pick this up in the morning.
