Signal does not reach downstairs
LeighGriffiths
Message 3 of 3
I have just had the fibre install upstairs,and the signal does not reach downstairs.Previously the router was downstairs before being moved by the engineer and everything was fine
Message 1 of 3
Hi @LeighGriffiths
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Message 2 of 3
Hi @LeighGriffiths
Are you using the eero?
