Smart plugs and ip cameras keep going offline due to wifi channel switching
YORKYUK
Whizz Kid
Message 20 of 20
Smart plugs and ip cameras keep going offline due to wifi channel switching, even tho I have set the channel number.
Does anyone have any ideas what is causing this?
I'd read on another talktalk post there's something the talktalk techies can do in the background on the router.
19 REPLIES 19
Message 1 of 20
You're very welcome @YORKYUK
Message 2 of 20
Hi YORKYUK
I'm so glad to hear this 🙂
Thanks Keith 🙂
Message 3 of 20
Yeah everything is working good now, thanks Keith.
Message 4 of 20
Message 5 of 20
Advised customer to change 2.4GHz channel to 1 as channel 4 was causing WiFi interference. For anyone else looking at this thread, only channels 1, 6 or 11 should ever be used in this band.
Message 7 of 20
Hi @YORKYUK
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed in), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so that I can find it easily.
Message 8 of 20
Hi Keith, yes I'd be happy for you to send that out to me.
Message 9 of 20
Hi @YORKYUK
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Message 10 of 20
No Problem 🙂
I'm sure @KeithFrench will pick this up with you shortly.
Message 11 of 20
Message 12 of 20
I've disabled wifi optimisation to allow Keith to assist further.
Message 13 of 20
In that case, as per my earlier post, please ask TalkTalk on here to disable WiFi optimisation for you. Then I can move forward with Tring to help you.
Message 14 of 20
I've checked and I've got the FAST5364 router.
Message 15 of 20
Message 16 of 20
Staff will switch off wi-fi optimisation when they are back, @YORKYUK, so after the weekend.
Message 17 of 20
There is another WiFi Hub that looks almost identical to the two Sagemcom models that I mentioned. It is the Huawei DG8041W and this does not support WiFi Optimisation at all. If you have this one then WiFi optimisation is not the cause of the problem.
Message 18 of 20
Thanks for the quick reply.
I have the WiFi hub router, not sure what version as I'm out the house at the min.
TalkTalk, can you please turn the WiFi Optimisation off on my router please.
Message 19 of 20
This can be down to WiFi interference or other causes, particularly if you use a 5GHz band channel in the range 52 to 140.
Which make/model of TalkTalk router do you have? If it is the Sagemcom FAST 5364 or 5464, they support a feature called WiFi Optimisation, which manages channel allocation automatically. If you have one of these routers, then request that TalkTalk disable this facility on your router, by simply requesting this in your reply. If it is the Eero, there is no user control over channel allocation at all.
