Solid Red light on router - no connectivity
Gizmo1981
Whizz Kid
Message 33 of 33
As title.
I have a D-Link DSL-3782 and since 1am this morning,  the connection dropped and the router went to a single red light for the power,  But the Broadband,  Internet, Wireless and Ethernet lights are all out.
I've tried unplugging the router for one hour and then plugging it back in,  rechecking the connections for the ADSL,  Even factory resetting the router by pressing in the small button at the rear of the router..
nothing works and it's still showing a solid red light.
I saw this on another post
The router having a permanent red power light is an indicator that it's failed the start-up diagnostics. Switch off the power to the router, wait a few minutes then repower.  If the light is still red after another 5 minutes then the router requires replacement.’
So Obviously it appears my router is FUBAR.
Any chance of a replacement or one that is more reliable?
:edit:
we have also ran a network test using talktalk's self help centre and that says there is an issue but after 8 and a half hours I really need this looking into at the earliest opportunity as I require a connection to do my admin and create content.
Playing GT5 on the Nurburgring Nordschleife with my Chrome Enzo Ferrari 😉
32 REPLIES 32
Message 21 of 33
hi,  Yep it's here and all connected up.
I'm not sure if it's a firmware thing,  But every so often when I'm in the router page configuring things,  The UI gets stuck and when I refresh the page it seems I'm logged out of the router and have to log back in again and try to retrace my steps to where I was prior to being signed out.
Is this something you're aware of from other users?
Is there any way of disabling the auto-sign out as it's kinda frustrating to have to keep logging back in until I'm finished and only then closing the tab.
thanks.
Message 22 of 33
Hi Gizmo1981
Message 23 of 33
Hi Gizmo1981
The router should automatically update once new firmware is pushed out.
The DSL3782 is one of our older routers so it's probably become faulty. Once the new Sagemcom hub is connected then once new firmware is available your router will be updated.
The firmware updates have to be done by TT, we don't have a file for the firmware update.
Message 24 of 33
Many thanks,  I've managed to borrow a router for the time being until it arrives.
This one is syncing up just fine so now I know 100% it was the DSL 3782 packing in.
One thing I did notice in the self-help section,  When I ran a line test it did say that the router required a firmware update but I wasn't able to find any downloads for firmware updates across talktalk's website in order to do this myself.
Do TT just push the updates or do we have an actual section we can download firmware updates?  Or are TT responsible for pushing the updates?
If the latter,  Can we not download the .bin files and update our firmware ourselves,  As I like to ensure drivers and firmware of hardware are fully up to date at the earliest time possible and being able to manually do this is something I'm accustomed to.
Message 25 of 33
Hi Gizmo1981
Sometimes they do arrive within 24hrs, mine have in the past.
We do say to allow up to 48hrs just incase.
Message 26 of 33
That's great thanks,  How soon am I likely to have the new one ready to go?
I know you say 24-48 hours but which is more likely?
Message 27 of 33
Hi Gizmo1981
Yes it could be a router fault. Once the new router is connected and if this resolves the no sync fault then I can check the sync speed for you.
Message 28 of 33
Is that because the router isn't functioning ( line not in sync ) ?
Or could that be down to something else entirely?
Message 29 of 33
Hi Gizmo1981
The line test is clear - no faults detected. I can't see the sync speed as the line is not currently in sync.
Message 30 of 33
Are you showing no connection issues prior to entering the property and confirming it is the router?
Can you see what the current sync speeds are to the socket?
Message 31 of 33
Hi Gizmo1981
Apologies for this.
I've ordered you a replacement router (Sagemcom WIFI hub) please allow 24-48hrs for this to arrive.
Message 32 of 33
The router sounds like it is faulty. I have asked one of TalkTalk's support to pick your thread up and replace it for you.
