Solid orange light no Internet
mantagte1
Message 20 of 20
My Internet went off at 4.15 am this morning router has a solid orange light,
I have gone through the service center and they found no fault.
I have also done a line check this also comes back as no fault showing,
Help
19 REPLIES 19
Message 1 of 20
That's great news, thanks for letting us know 🙂
Message 2 of 20
Hi all new router works perfectly thank you all for your help
Anonymous User
Message 3 of 20
Thank you.
Message 4 of 20
Yes will do Chris
Message 5 of 20
No problem, please let us know how you get on with the new router
Message 6 of 20
Thanks Chris fingers crossed that sorts out my problems
Message 7 of 20
OK, I've ordered the router, it should be with you within a couple of days
Message 8 of 20
Yes please if you could
Message 9 of 20
I think we should test with another router, would you like me to send one?
Message 10 of 20
No I'm afraid not
Message 11 of 20
Thanks, do you have another router that you can test with?
Message 12 of 20
Yes it is
Message 13 of 20
OK thanks. Is your router currently connected to your test socket, if you have one. Your guide to main phone sockets - TalkTalk Help & Support
Message 14 of 20
Do not have a house phone on the premises so unsure
Message 15 of 20
Hi mantagte1,
Are you also having problems with your telephone service, is there a dial tone?
Message 16 of 20
Thank you
Message 17 of 20
Thanks. I'll ask TalkTalk to investigate for you, as this normally indicates an authentication issue.
mantagte1
Message 18 of 20
Talktalk WiFi hub
Dev ver Fast 5364-3.T8
Message 19 of 20
What make/model of router do you have?
Anonymous User
