on 15-06-2024 01:00 PM
My eero router failed this morning (so support say) so another is on order but it won't arrive until later in the week. I work from home and have a child with the Internet being used for TV as well.
I've tried using a third party asus rt-ax82u router but it won't authenticate.
I spoke to support and they said despite forum posts saying this was possible, I am not able to use third party routers.
Is there a way I can have it permitted based on the fact it'll only be for a few days?
on 17-06-2024 06:48 AM
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 15-06-2024 01:14 PM
Most third-party routers use the same profile as the eero, but I can't guarantee that it won't require this change. So much also depends on who has provided your full fibre. The relevant VLANs will probably need to be set up in your router. This gives some guidance, but I am not sure if it predates full fibre or not:-
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
I have asked one of TalkTalk's support to pick your thread up and advise you.
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if you can, please include the serial number from your ONT in the Private Notes section. Please also try to include an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:-
on 15-06-2024 01:06 PM
Thanks Keith. I followed other posts on here and it only seemed to be the VID that needed changed (other than the settings mentioned on the talktalk support site)
Support were VERY firm that no third party router would work and they could not undertake the line change that I've also seen mentioned on other posts here.
I'd ask what router is compatible but as far as I could tell, it could see the connection and just wouldn't authenticate with talktalk
on 15-06-2024 01:02 PM
Currently, you can still use your own router if it is compatible with the TalkTalk network and configured correctly.
