Using a TP-Link WiFi Extender
thegodplato
Message 26 of 26
Work have purchased for me a TP-Link AV1000 to boost the wi-fi signal.  It is plugged into the Talk Talk router and the works laptop has now got a stable internet connection.  However, we are experiencing some problems:
1) Mobiles connected to either the TalkTalk router or the TP-Link do not show images anymore when on social media sites - turn wi-fi off, use mobile data and images show.
2) SkyBox keeps losing wi-fi connection - yes I know this may well be a Sky issue but only started when we got the TP-Link device.
I was wondering if there are any settings I should be changing on the TalkTalk router to rectify this?
25 REPLIES 25
Message 1 of 26
Can I just confirm, is this happening with just the router connected and the adapter removed? What is your current set up at the moment?
thegodplato
Message 2 of 26
Hi, I have still got issues with the router.  As much as turning off Kids Safe has worked, we need to turn it on to allow Splashtop.com as acceptable site so my wife can remotely access her work PC.  So we are back to square one I guess albeit we can keep turning Kids Safe on and off but it is a faff as you need to enter Splashtop.com in the Allowed sites section every single time you need to use it.
Message 3 of 26
Ok thanks for the update and please let us know how you get on.
thegodplato
Message 4 of 26
So, I think we finally have got it working on both PC and mobiles.  I'm not sure if there is an issue with how the Home Safe thing works though.  In order for my wife to connect to her work PC they used some software called Splashtop and that had to be entered under Specific Websites in order for the connection to be made. We had Kids Safe turned on but under the Website Categories section all the items listed had to be turned off.  We also had various Social Media sites entered in the Specific Websites section and Allow was ticked.
I have now turned off Kids Safe and everything seems to be working fine which makes me think that having it set to on but nothing selected under Website Categories causes it to be confused.
Lets see if it continues to work ok.
Message 5 of 26
In regards to the social media issue, could you log into your My Account and check to see if you have HomeSafe/KidSafe set up please?
thegodplato
Message 6 of 26
I have disconnected the PC from the WiFi and used a lead to provide wired connection but that has made no difference, still no access to social media on the PC. Don't forget that this is more to do with the lack of full access to Social Media sites via WiFi on our mobiles.  Its really odd, we haven't changed anything on the PC or our mobiles.  The only thing that has happened is changing provider to yourselves from Vodafone and, since changing providers, finding the WiFi signal not as good hence the Extender requirement.
Message 7 of 26
Can I just confirm, does this also happen if you connect one of the devices wired? I'm just trying to confirm if this is solely related to the wireless connection?
thegodplato
Message 8 of 26
Hi, no unfortunately not.  I have attached what we get when on a PC for Facebook.  And when on mobiles, no pictures appear and other strange things happen for my daughter on snap chat, etc.  The only way we get everything working fine on our mobiles is to use mobile data which leads me to think it has to be a router/cabling network issue causing the wi-fi to not work correctly.
Message 9 of 26
Hi thegodplato,
And it doesn't make any difference if the wi-fi extender is unplugged?
thegodplato
Message 10 of 26
The replacement router has made no difference.  Is there anything else we can try?
Message 11 of 26
Hi thegodplato
thegodplato
Message 12 of 26
If you can organise a replacement router that would be appreciated.
Message 13 of 26
Hi thegodplato
Would you like us to send a replacement router for testing?
thegodplato
Message 14 of 26
This issue is still ongoing, I don't have another router to try.
Message 15 of 26
Do you want to try swapping out the router to see if that helps ?
thegodplato
Message 16 of 26
Hi, its still odd.  Quite a bit hit and miss whether images show or not on FB and Twitter.  Videos stop playing half way through on TikTok and they can't send messages on SnapChat.  Have tried 2.5Ghz and 5Ghz on both the TalkTalk router and the Extender, and also with the Extender turned off but it doesn't seem to make any difference.
Message 17 of 26
Can you check, if you turn the extender off, so devices are connected to the router, do images show then, is it only when the extender is on that images are not showing ?
thegodplato
Message 18 of 26
Hi, I have checked with the boss at home ( the kids! ) and they still cannot get on their all important social media sites like SnapChat, etc. I too do not get images on Twitter.  Odd.  But thanks for your help so far!
Message 19 of 26
I've turned off optimisation so the wifi channel will remain static.
I've also split your wifi SSID's while we test. the 5Ghz wifi name looks the same but the last digit will be a '1'.  Passwords remain the same.
Test and see if there is any improvement.
thegodplato
Message 20 of 26
Hi, it doesn't seem to make a difference unfortunately.  And our new Sky box is losing connection several times a day now.
