Very poor spread of wifi signal
fiona12345
Message 4 of 4
I'm on fibre 65 VOIP, I was upgraded late last year.
My problem is that I only get a decent wifi speed in the room where the router is. The signal doesn't transmit well to the other rooms in my property.
I've got a small flat, the router is where the cables come into my flat - in the hall. The hall is in the centre of the flat and all the rooms come off the hall. Nowhere in the flat is more than 6 metres from the router. Despite this I regularly get speeds of 1 or 2mb even when I'm only 3 or 4 metres from the router. It's dire.
I've had to buy a wifi extender to allow my desktop pc to connect.
I ran your connection test a couple of weeks ago and it said there was a fault. However I didn't get any messages to say it was resolved. I've run the connection test again now and again it says there is a fault.
I've checked and no-one else is using my wifi. My router was set-up and plugged in by the engineer who installed the fibre
Please can you help.
Fiona
3 REPLIES 3
Message 1 of 4
If you still need help I can offer a lot of support with any WiFi issues. However, I do need to know the make/model of router that you have first.
Message 2 of 4
Hi Fiona,
Do you still need assistance with this?
Message 3 of 4
Hi Fiona
Are you using the Sagemcom WIFI hub?
