WIFI Hub Connected speed v actual speed
DStar
Message 10 of 10
My WiFi hub is connected to BT network at 66MB but my connected speed on from Lan port to W10 laptop is 53MB with only device connected (for testing) , is this usual ? Seems quite a loss in speed.
Does anyone know latest version of firmware / hardware / software for the WIFI Hub ?
Many thanks
9 REPLIES 9
Message 1 of 10
No problem 🙂 Usually after a 30 minute router power down the throughput speeds should increase slightly. The current firmware for the Sagemcom wifi hub is V158 but we do have a newer version coming hopefully in April.
Message 2 of 10
Hi Michelle
Thanks for testing it so quickly, much appreciated 🙂
I'll try that later.  Is there a possibility restarting after 30 mins could give me a slower session ?
Whats the latest version of firmware / hardware / software for the WIFI Hub ?
Message 3 of 10
Thank you. I've run a test on the line now which hasn't detected a fault and I can see that the sync speed has increased slightly over the last week. The throughput speeds are usually around 80% of the sync speed. Could you try powering down the router for a full 30 minutes and then retest the speeds again please as this will reset the current session and can often increase the throughput speeds.
DStar
Message 4 of 10
Hi Michelle
Profile updated thanks 🙂
Message 5 of 10
  • Name
  • Telephone number
  • Alternative contact number
DStar
Message 6 of 10
Hi Michelle
It's wired Windows 10 laptop, just so I could eliminate WiFi interference causing speed reduction.  When tested it was the only device connected
Message 7 of 10
I see, thanks for confirming. Is this speed test wired or wireless? Would you like us to check your connection stats for you?
DStar
Message 8 of 10
Hi Michelle
Yes I'm a Talk Talk customer, sorry I meant connected to BT OpenReach managed network
Message 9 of 10
Apologies for the confusion, are you a TalkTalk or BT customer?
