Wi-Fi issues on FaceTime and other apps to Canada
Nosaj
Sightseer
Message 12 of 12
Hello. I have been having intermittent issues with using FaceTime, iMessage, WhatsApp video calls to Canada for a long time now over Wi-Fi. I have even tried video calling on instagram and this is also the same as mentioned. Sometimes, but not often, it connects for a minute or two, then just cuts out. All work when I use 4G data. Please advise.
11 REPLIES 11
Message 1 of 12
I can't see it being a router problem. Do you know which service provider the person in Canada is using?
Message 2 of 12
I do not communicate with anyone else overseas and the person in Canada communicates with another work colleague in Australia with no issues. It seems to mostly be my end with the issue nearly all the time. It’s very frustrating when on a work call and it cuts and then also not being able to get back to them with a message and having to lay it out in an email. I’m wondering if it’s an internal router setting that needs changing at my end possibly?
Message 3 of 12
Do you communicate with anyone else overseas by whatsapp? Does the person in Cananda communicate with anyone else in the UK? If they do they experience any issues with that connection?
Message 4 of 12
As far as I can work out it’s just my end. Canada calls and it gets through but cuts off intermittently. calls last anywhere from seconds - 5+ minutes. Again, when I call it rings out mostly and same with calling on WhatsApp/FaceTime and iMessages not being received even though they say delivered
Message 5 of 12
Thanks for trying that. Does it make any difference who initiates the call, you or the person in Canada?
Message 6 of 12
Turned off router for 45 minutes, had two FaceTime video calls to Canada, first connected then cut off after around a minute, second attempt straight after just rang out as often happens with Canada end not receiving the call.
Message 7 of 12
OK thanks. Could you switch your router off and leave it off for at least 30 minutes, then switch back on and retest. Please let us know how you get on
Nosaj
Sightseer
Message 8 of 12
all info updated.
thanks,
Message 9 of 12
OK thanks. Can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 10 of 12
Hi Chris,
yes all these apps work as they should every time with UK communication.
Chris-TalkTalk
Message 11 of 12
Hi Nosaj,
Do all these apps work OK when calling people in the UK?
