Wifi Hub/Router Faulty Dropping Wifi Frequently
RicMill15
Sightseer
Message 14 of 14
Been have Issues With wifi/internet Dropping frequently, Causing TalkTalk Tv to Reboot and our phones to keep disconnecting and connecting to internet
Tried rebooting wifi hub/router (sagecom Fast 5364-3.TB) numerous times which has no effect but Line test seems to be ok
Just getting very annoying especially when ur watch tv and it reboots due to wifi/internet drop
Seems a common issue
Wondering if or how i can get a new wifi Hub/router sent out to me ?
Kind Regards
Richard
13 REPLIES 13
Message 1 of 14
Hi Richard
How are you getting on, do you still need help with this?
Message 3 of 14
Hi @RicMill15
@Debbie-TalkTalk has asked me to help you with your wireless issues.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
Message 4 of 14
Hi Richard
Our Community Star @KeithFrench provides really good advice on improving wireless performance.
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 5 of 14
Hi Debbie
It wireless that is dropping i have no devices wired to router due to being on otherside of room to my tv and smart box
kind regards
Richard
Message 6 of 14
Hi Richard
Apologies for this. Are any wired devices dropping connection or is this only affecting wireless?
Message 7 of 14
Hi Debbie
sorry for late reply
Given it a week to see how it is
Still getting abit of Dropping, Not as Bad as last router tho which was ridiculous
Kind regards
Richard
Message 8 of 14
Hi Richard
That's great 🙂
How's the connection been over the weekend?
Message 9 of 14
Hi Debbie
Received Router and installed it yesterday , So far connection is Good and had no Dropping of wifi so far
Hopefully Solved problem 🤞🏽
Thank you for your help
Kind regards
Richard
Message 10 of 14
Hi Richard
Thank you 🙂
Message 11 of 14
Hi Debbie
Sorry just seen ur message you sent yesterday
i have added our landline to Community Profile Now
Kind Regards
Richard
Message 12 of 14
Hi Richard
Apologies for the delay.
Please can you add your TalkTalk landline number to your Community Profile, I can then send you a replacement router.
Divsec
Message 13 of 14
Hi @RicMill15 your post has been escalated but with the holiday weekend you may have to wait for Tuesday to hear further.
