on 13-04-2024 03:18 PM
For the past month or my Wifi keeps dropping out on various devices (e.g. smart speakers, mobile phones) connected to my 2.4ghz channel. Every few minutes in some cases. The 5ghz channel is working fine.
I've restarted all of the devices, reset the router, even left it switched off completely for a couple of days. The devices in question don't have 5ghz capability so I can't swap them over to that. Very frustrating as my house is in a 4g blackspot, so I rely on the Wifi for my mobile phone.
I've tried changing the 2.4ghz channel (I've tried 1, 6, 11 and autoselect so far). No joy.
Does my router need an upgrade? Any other suggestions?
It's a SAGEMCOM router, Device Version: FAST 5364-3.T8, Serial No. N7183524N005258. I'm on Fibre35.
Thanks in advance!
on 19-04-2024 11:35 AM
@KeithFrench your offer of support is always very much appreciated 🙂
on 19-04-2024 11:02 AM
No worries @Debbie-TalkTalk even if my help was not needed in the end.
on 19-04-2024 10:33 AM
That's great news 🙂 I have sent you a Private Message with a link to a short survey for the Community.
Thanks for your help @KeithFrench 🙂
on 19-04-2024 10:31 AM
Between switching off the Optimisation and Keith's offer of help, I think I'm sorted! Thank you 🙂
on 19-04-2024 06:01 AM
Hi Joystercatcher
Do you need any further help with this?
on 18-04-2024 11:40 PM
Thanks @nseedy - it does seem to be much better already!
on 16-04-2024 10:52 AM
on 16-04-2024 10:50 AM
@Joystercatcher has sent me a PM & I have sent my guide over.
on 16-04-2024 08:17 AM
Thanks nseedy.
We have switched the WIFI optimisation off for Joystercatcher.
on 16-04-2024 08:11 AM
I had the same problems that's been solved by asking talktalk to switch off WiFi optimisation on my router. Been hugely better since it was done.
on 15-04-2024 10:27 PM
Thanks @KeithFrench - I've sent you a private message 🙂
on 15-04-2024 11:26 AM
Hi Joystercatcher
This has now been switched off.
I can see that @KeithFrench has offered to help.
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue. Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others. If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc. one of the TalkTalk team will jump in and help out.
on 15-04-2024 11:23 AM
Thanks Debbie - that's added.
Are you able to disable Wifi Optimisation as Keith suggests below so that I have more control over the router settings - or is there something else we can try first?
on 15-04-2024 08:46 AM
HI Joystercatcher
Please can you add your name and TalkTalk landline number to your Community Profile.
on 14-04-2024 01:17 PM
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
