Wifi mesh
Colinu
Message 2 of 2
I'm looking too extend my WiFi coverage in my home which is very poor. I've been told a mesh network will improve this.
Can anyone advice me which system to purchase?
We have Fibre 150 and the new router supplied.
1 REPLY 1
Message 1 of 2
Which make/model of router is that, the Hub2 or the eero 6?
Before going down the route of buying extra hardware it is best to make sure what the underlying problem is. Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
