on 28-07-2023 08:04 AM
I think the firmware has been upgraded recently as some of the navigation in the admin web interface no longer works - clicking a button doesn't navigate to the page etc
Also I am having frequent wireless dropouts. Internet connection itself is fine as also have a wired device and ping test is stable. Wireless drops out for around 2 minutes every hour or so.
Anyone else experiencing the same or any suggestions on how to roll back firmware (I know it's new as now has an option for guest network)
Current version
TalkTalk Wi-Fi Hub
version SG4K100174
on 03-08-2023 10:48 AM
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed in), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so that I can find it easily.
Still having some wireless dropouts I'm afraid, on the new router. Seems specific to 2.4Ghz so going to source another adapter for my PC and try that
on 03-08-2023 10:47 AM
Yes please if you could send the guide over?
on 03-08-2023 08:30 AM
Just checking back in to see how you're getting on?
Thanks 🙂
on 01-08-2023 04:40 PM
Whenever the router's DNS server cannot resolve a domain name by going up the hierarchical DNS tree, it puts an entry to this effect in the system log. There is a bug in recent firmware where the severity of these messages has been set wrong (they should be set to informational). This means they cannot be filtered out in the UI.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
on 01-08-2023 07:05 AM
How are you getting on?
on 28-07-2023 03:16 PM
You're Welcome 🙂
on 28-07-2023 03:14 PM
Thank you
on 28-07-2023 02:18 PM
I'm not aware of any issues that would cause wifi drops or increased DNS errors to show in the logs, so I'll get a router out and see if this shows the same behavior.
on 28-07-2023 02:13 PM
Hi, that would be useful for a first test.
Are you aware of any know issues with the latest firmware, and when it would have been updated?
on 28-07-2023 01:47 PM
would you like to swap out the router first to see if it is hardware or firmware related.
on 28-07-2023 01:43 PM
I'm experiencing it on my PC and my phone. They are both 2.4G connections as nothing here to test 5G.
I've noticed a lot of dns errors in the log files too ....
| 28.07.2023 13:36:56 | Info | SYS | Modem login was successful |
| 28.07.2023 13:29:01 | Error | DNS | DNS name resolution failure (_xmpp-client._tcp.scs.samsungqbe.com) |
| 28.07.2023 13:27:56 | Error | DNS | DNS name resolution failure (_ldap._tcp.dc._msdcs.127.0.0.1) |
| 28.07.2023 13:12:56 | Error | DNS | DNS name resolution failure (_ldap._tcp.dc._msdcs.127.0.0.1) |
| 28.07.2023 13:09:00 | Error | DNS | DNS name resolution failure (_xmpp-client._tcp.scs.samsungqbe.com) |
| 28.07.2023 12:58:29 | Error | DNS | DNS name resolution failure (farm.plista.com) |
| 28.07.2023 12:57:56 | Error | DNS | DNS name resolution failure (_ldap._tcp.dc._msdcs.127.0.0.1) |
| 28.07.2023 12:55:10 | Info | WIFI | Device <70:DE:F9:92:AA:F2> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV]) |
| 28.07.2023 12:54:33 | Error | DNS | DNS name resolution failure (_xmpp-client._tcp.scs.samsungqbe.com) |
| 28.07.2023 12:53:57 | Error | DNS | DNS name resolution failure (_xmpp-client._tcp.scs.samsungqbe.com) |
| 28.07.2023 12:53:20 | Error | DNS | DNS name resolution failure (_xmpp-client._tcp.scs.samsungqbe.com) |
| 28.07.2023 12:52:44 | Error | DNS | DNS name resolution failure (_xmpp-client._tcp.scs.samsungqbe.com) |
| 28.07.2023 12:52:08 | Error | DNS | DNS name resolution failure (_xmpp-client._tcp.scs.samsungqbe.com) |
| 28.07.2023 12:51:48 | Info | WIFI | A WiFi device <70:DE:F9:92:AA:F2> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV]) |
on 28-07-2023 08:10 AM
Are the wifi drop outs to all devices or just a selected device ?
