no Internet
judyj1
Message 3 of 3
I wonder why does it say connected without internet? I noticed this problem occour mainly during night. Anybody has/had a similar problem and how did you resolve it.
Message 1 of 3
Hi @judyj1
Have you tried Keith's suggestion of rebooting the router?
Message 2 of 3
That means that your device is connected to the router, it will then attempt to see if it can connect from the router to the internet, which is where it fails. This can be due to several reasons, but the easiest fix is probably to reboot the router. If it is still causing problems, what devices are affected & how do they connect to the router, via wireless or an Ethernet cable?
Anonymous User
