router wifi
bazer11
Message 25 of 25
hi what was the fix that stopped the sagem router from dropouts was it a steering problems between 2.4 and 5,0 bands baz
ex comms engineer
24 REPLIES 24
Message 21 of 25
hi, yes i was talking about the the problem when the routers light was ok but virtually no or very slow internet communication at the moment im mainly using wifi just use an older pc to watch tv in the back room even with a ethernet connection this can be  very cloggy at times one thing when logging into the forum do have to receive a access code each time sapita thanks baz
ex comms engineer
Message 22 of 25
Hi @bazer11
Do you mean the one about the router's white light being on but no internet? This was a DNS issue as far as we were told, it affected internet access for Ethernet as well as WiFi connections.
With your subject title only mentioning Wi-fi, that is not the same issue.
Please can you clarify exactly what your problem with WiFi is?
Message 23 of 25
it was on the service status page that a fix for this problem   this has now been removed also i thin talktalk had bad press about this maybe the  admins will answer
ex comms engineer
Message 24 of 25
Hi @bazer11
I do not know what you mean, all such cases of WiFi reception need to be addressed individually, as everything that causes these issues is unique to each property.
