on 29-04-2019 01:43 PM
I'm trying to set up a web server at home. I've set my computer and the server up and all works fine from within the network. It gets complicated when trying to set up a hotname for it.
I started with the free no-ip service, but apparently this router is not compatible with it : See document is that true ?
I also tried using ddns with the duckdns service, again I didn't manage to make it work, I read there that the ddns is broken on those router, again is that still true ?
Anything else I could try ? Or do I have to change my router ?
Any help appreciated,
Thank you
on 29-04-2019 02:49 PM
Hi ryssbowh,
Glad to hear that you managed to get this sorted 🙂
on 29-04-2019 02:14 PM
Never mind, it all works correctly, I was doing all my tests from within my network...
So for those who struggle with this : always do your test with a connection outside of your network (4g for example)
