when can I expect re-connection to internet?
kannank
Message 27 of 27
(edit: mods, can you please move to fiber forum please? I have fiber 35 account)
I moved house and got an email saying I can connect my router and the connect should start to work. Also I got conflicting SMS stating I need/ dont need an engineer to setup.
Earlier the connection was through optic fiber, so had the router connected directly via ethernet (DHCP setting).
now, after move, it is back to copper and hence I have connected the phone line and changed the IPV4 setting to PPP.
anything else needs to be changed?
The orange light in the router is flashing slowly and no internet.
Anything I need to check/ reconfigure?
When can I can expect to be reconnected?
thanks.
26 REPLIES 26
Message 21 of 27
Stock talktalk hub (version 2?).
grey one with light low center.
Message 22 of 27
Ok thanks. Which router do you have?
Message 23 of 27
Hi Chris,
yes, the router is ON and connected to master socket.
Message 24 of 27
OK thanks. Is your router currently switched on and connected to the master telephone socket?
kannank
Message 25 of 27
hello,
Apologies, I have just updated with the updated number of the new house.
k
Chris-TalkTalk
Message 26 of 27
Hi kannankariraman,
Is the telephone number in your community profile your current TalkTalk landline telephone number?
