on 18-04-2024 07:31 PM
I have noticed my firestick and various other devices connected to my eero router via 2.4ghz.
I run a speed test on my phone and getting 500mb download, firestick test only gets 70mbs and buffers a lot, how can I change it on to 5.0ghz when all I have when scanning for net works no 5.0ghz appears and don’t see any way on the erro app to change or turn i on, any help or advice, thanks ☺️
on 19-04-2024 01:31 PM
19-04-2024 01:26 PM - edited 19-04-2024 01:30 PM
What WiFi channel is your Eero using in the 5GHz band, it is not something like 155 is it, if so, a lot of devices do not support such a high channel. To check:-
on 19-04-2024 07:01 AM
Hi Cozimos
Apologies for this. Where do you see the 2.4ghz?
In the router settings/wifi settings does it not show the router name?
