900mb connection dropping to 94mb
Ryano1
Message 6 of 6
Encountering a weird issue where my connection is dropping to 94mb up and down every few days. To restore full speed need to reboot the gateway eero. Another user encountered the same problem: https://community.talktalk.co.uk/t5/Full-Fibre/Repeated-problem-with-Eeros-and-Fibre-900/m-p/3039705... They seemed to resolve by swapping the Ethernet from the ONT to the gateway Eero. Having tried this, it seemed to work for a few days, but this morning speeds are back to 94mb. Any ideas anyone? Eeros are on the latest software.
5 REPLIES 5
Message 1 of 6
How have you found the connection/speeds over the weekend?
Message 2 of 6
Thanks for the update and I'm glad to hear this. We'll check back in with you on Monday to see how you're getting on.
Ryano1
Message 3 of 6
I replaced the Ethernet cable again between the ONT and the Eero with a brand new Ethernet cable. This seems to have resolved the issue, as the speeds haven’t dropped for a couple of days. I’ll continue to monitor.
Message 4 of 6
How are you getting on? Did you try powering down the ONT and retest the speed again?
Message 5 of 6
Try turning off the ONT for a full 30 mins & if it is still bad, connect a wired (Ethernet) device, if you have one, directly to the ONT in place of the Eero.
