yesterday - last edited yesterday
I have received an email from TalkTalk saying that Callsafe will shortly be chargeable. As far as I am aware, as I am using VOIP (digital voice) and call safe is not avaiable, I am assuming this is an error and no additional charge will be made to my account.
18 minutes ago
Sure it will be sorted soon ! It's well worth £1 a month before the days of callsafe we were getting about 5 or 6 nuisance calls a day with callsafe its zero.
23 minutes ago
Yes, it is undoubtedly confusing! And annoyingly My Account does not always behave as it should. But it seems that you do have it and the options are as advised.
27 minutes ago
@ferguson Yes that's fine I am Ok with that the problem is that according to my account its not compatible with Voip therefore its not available under manage settings. The Web site now says callsafe is available to all, clearly a change of policy by Talktalk.... my questions have been flagged and escalated .. perhaps have a definitive answer soon
37 minutes ago
OK, in which case you are going to be charged £1 a month from January, or you can cancel beforehand if you do not wish to continue.
an hour ago - last edited an hour ago
Yes, as far as I can tell, we certainly have had no nuisance calls, calls are being screened too
regards
an hour ago
Is it working on incoming calls?
6 hours ago
Yes @davidl1 and I have escalated this for you and I will be able to give you an update on this thread as soon as I get a respond.
6 hours ago
That doesnt seem to be the case, its a bit confusing ! I have asked similar on this post, just awaiting clarification. I have upgraded to voip and still have callsafe ! But it dowsnt show on my account dashboard
7 hours ago - last edited 7 hours ago
Thanks @Gliwmaeden2
7 hours ago
@Weevie, just set up Last Caller Barring instead.
Information about it is found using the forum search engine.
8 hours ago - last edited 8 hours ago
Hi @Weevie To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
8 hours ago
I understand that Callsafe is not available on Full Fibre (VOIP) - Is there another way to block unwanted callers ?
because before Callsafe, we used to get many spam calls and I will not be very happy if they resume, if I upgrade to FTTP
12 hours ago
You welcome @davidl1.
12 hours ago
12 hours ago
I have escalated the issue to my manager too and once we have an update, we will be able to respond here on the thread.
12 hours ago
Brilliant. once again thanks for your help
12 hours ago
Thanks for your help perhaps you could also escalate the issue I noted that @Gliwmaeden2 has flagged it up
many thanks
12 hours ago
I understand, the issue has been escalated and you will be updated when we receive any respond. Is there anything else we can assist you with?
12 hours ago
Thanks again for your reply I noticed that @Gliwmaeden2 has flagged the issue up perhaps you could escalate it ? I am much too busy at the moment to make long phone calls, it is a general issue with any luck it should be sorted at some point.
12 hours ago
I understand, is there anything else we can assist you with?
