Channel problems
Dazza123654
Message 2 of 2
Hi I have had a eero6 Installed last week and having problems with my wifi dropping or very poor upstairs got a erro repeater not much better check with WiFi analýzer and it's stuck on channel 11 Evan if I unplug everything can you check if channel monitor is deactivated it should switch to a stable channel automatically should it thanks
1 REPLY 1
Message 1 of 2
If you want to send me screenshots from your analyser, I will take a look for you. I will need (not knowing which analyser you are using) these ones:-
  1. AP View showing your eero networks
  2. 2.4GHz channels
  3. 5GHz channels
  4. Signal strength/time graph (let this run for five minutes before taking the screenshot.
Please can you also tell me your network name and give me a rough description of where the gateway & extender eeros are & what is near them in terms of electrical equipment, metal objects or water tanks etc. Then PM everything to me (to preserve your privacy).
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
