City Fibre network eero 6 cannot get external IP address
PeterR7
Message 8 of 8
Until my recent renewal all worked well with Sagemcom FAST5464 Router but now, having been issued with an eero 6, it will not connect to the internet because it cannot get an external IP address. I have followed the instructions to switch everything off and start all over again numerous times but always get the error (bluetooth and presence of ethernet cable get ticks). I've reverted to the Sagemcom and all works fine. What is the fix please?
7 REPLIES 7
Message 1 of 8
That's great Peter, thanks for letting me know 🙂
Message 2 of 8
Thanks, Chris. All is now fixed.
Message 3 of 8
Hi @PeterR7
From my experience once the change is done you'll be able to use your eero . In my case I have had to temporarily go back to a hub 2 for some testing and I was surprised to find on the Eero profile, the hub 2 is happy on that one as well.
Message 4 of 8
OK, I've requested the profile change, this should go through within the next few minutes
Message 5 of 8
Chris,
Very happy for you to do this & realise there will be a service interruption but I've had other problems (no concern of yours) with this switch to eero  since circa 4 July; to the extent that my confidence in TalkTalk is pretty low at the moment. So my only worry is that you changing my profile with not make my old router inoperable if the eero still does not connect after you do your stuff.
Best,
Peter
Chris-TalkTalk
Message 6 of 8
Hi PeterR7
As Keith has said this appears to be a profile issue. Are you OK for me to change your profile now, there may be a short interruption to your service
Message 7 of 8
CityFibre networks often need a profile change when connecting an eero. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
