on 23-12-2023 07:02 PM
On my previous land line service, last number recall offered to “call the number by pressing 3 on the phone and said that there might be a charge for this service.” This worked.
With TT’s implementation, after dialling 1471 the last number recalled is read out and then says “ to call this number press 3 “ There is a short pause and then says “.you have not dialled any number” then another short pause says “ please hang up.
The instruction to dial the number when 3 is entered has clearly been omitted, in my opinion. It is important to me that this feature works as intended as I could not remember an eleven digit number and probably beyond most people.
Please investigate.
Gordon
on 19-08-2024 01:42 PM
Good afternoon,
I'm sorry to hear this. I've asked our Faults Escalation Team to take another look at this so I'll post back as soon as we receive an update.
on 19-08-2024 01:24 PM
Michelle, (Support team Staff)
We had a short duration mains failure recently and the fix applied by your upgrade team has failed to work since then.
Last number recall, 1471 , reads the number then asks to press 3 to phone the caller. No auto dialing and a few seconds later the voice tells me I have not dialled the number and a few seconds later am told to please hang up.
This process is exactly the same as I reported in May this year which you escalated to the Technical Fault Team which implemented a fix.
After the short mains failure I attempted a 1471 recall which failed to announce the last number and so rebooted the GRANDSTREAM VoIP which then gave me the number but did not dial it. I noted that the EERO 6 appeared to work normally after the mains drop, but I did reboot it the next day.
on 19-02-2024 06:50 AM
Has there been any change since Friday?
on 16-02-2024 11:45 AM
Hi again,
Would you mind retesting later on today and letting us know if this is now working please?
on 16-02-2024 07:08 AM
Thanks for the PM. I'm sorry that you haven't been contacted. I've escalated this straight back to our Faults Team and have asked if they can provide an update ASAP.
on 05-01-2024 10:56 AM
You're welcome and hopefully we'll hear back soon.
on 05-01-2024 10:54 AM
Hello Michelle,
Thank you for passing this to your Faults Escalation Team, I look forward to their input.
Gordon
on 05-01-2024 07:37 AM
Good morning,
I've passed this over to our Faults Escalation Team for further investigation. I'll post back here as soon as receive an update. It's possible that the team may also try and contact you directly.
on 04-01-2024 04:53 PM
Hi Chris,
Went though your procedure - but the end result after dialling 1471 was the usual readout of the last number called, followed by an invitation to dial 3 to connect with the last caller, then a pause of a few seconds then a comment that I had not dialled any number, short pause then asked to please hang up.
There was no mention of “the 1471 service is now closed”.
Are we certain that the firmware to dial the last caller is installed in the DVA (grand stream)? Just a thought.
Thank you for all your help
Gordon
on 04-01-2024 02:03 PM
OK, could you try the following: plug the DVA (grandstream) into the ONT, wait for the broadband light to come on then perform a pinhole reset of the DVA, this should get the phone light back on within about 5 mins, once that comes on can you change setup back to normal. Please let us know how you get on
on 04-01-2024 12:21 PM
Hi Chris,
on 03-01-2024 11:10 AM
Hi Gordon,
Could you try switching the ONT off for at least 30 minutes then switch back on and retest. Please let us know how you get on
on 02-01-2024 05:50 PM
Thank you Michelle,
Yes I have disconnected the complete network from mains power, reconnected after several minutes and dialled a call from my smart phone to establish the last call. Then dialled 1471 and was asked to dial 3.
As previously I was told that I had not dialled the number, there was a short pause and was then asked to hang up.
I did try the same routine and dialled 0 instead of 3, but this did nothing and was asked to hang up.
Thanks again
Gordon
on 27-12-2023 07:36 AM
I'm sorry for the delay. Is this still happening since your last post? Could you try powering down the DVA and then retesting this again please to see if this is still happening?
