Drop Out
Theshed
Message 14 of 14
We have recently upgraded to Fibre 500, but since then we are experiencing 'dropout'.
Is there anything we should or need to do to stop this ?
13 REPLIES 13
Message 1 of 14
Let's keep our fingers crossed on that okay. Thanks
Message 2 of 14
Ok, so reboot of system and individual devices. Some behind the scenes updates and we have WiFi again.
I just hope that is it, and we do not fall off again tomorrow !
Message 3 of 14
Good luck, I'll be here to hear how it goes. Thanks
Theshed
Message 4 of 14
Ok, thanks, wish me luck !
Message 5 of 14
Thank you for confirming, I'll need you to contact our full fibre team so they can have this looked into for you. I've provided the contact details below along with a link directing you to our chat team okay. Thanks
03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
https://community.talktalk.co.uk/t5/FutureFibre/bd-p/FutureFibre
Theshed
Message 6 of 14
Yes I'm home.
Message 7 of 14
Will run checks on this for you, kindly confirm if you are currently at home so we can get started. Thanks
Theshed
Message 8 of 14
I despair !
Mobiles and Google homes will not connect to WiFi.
I have tried turning off/on and forgetting network before reconnecting but still no joy.
I have had to buy more mobile Data, why is it so difficult ?
Message 9 of 14
Please try to keep the TV connected wirelessly as it's working fine, before accessing google please make sure you are connected to the router. Please also try forgetting network and refreshing the connection, will take it from there if it still gives you any issues. Thanks
Theshed
Message 10 of 14
Well, I'm back.
Tv took quite a bit of re-setting up last night, it is hard wired but wouldn't connect. Surprisingly it did connect wirelessly ?
PC is hard wired and appears ok.
Both up and down Google homes have again lost WiFi, as did my mobile. Mobile returned after reset, but Google still refuses.
This has only happened since the upgrade, surely there is something that can be done to have consistent service ?
Message 11 of 14
Hi there @Theshed, I'm pleased to hear everything is working now and yes you can monitor to make sure everything is okay and let us know. Thanks
Theshed
Message 12 of 14
Well, following a VERY fraught few hours, during which I was reduced to tears of frustration we appear to be back online.
In brief, the number supplied was automated, they advised text messaging in which the bot kept sending us around in circles.
Calling the number again, it said they would send us an Email then hung up, not much good with no internet !
I bought data for my mobile but the information was what we already had.
The text service sent the same useless link, FIVE times, which did not cover our system.
Three different support agents tried to help, starting afresh at each one when we where cut off. The third told us to reset the router after he updated the firmware. Then, nothing, no drop out, no WiFi at all.
I waited on line for an age, constantly being told the quickest way was online or text. Erm ? No.
Eventually someone answered, I explained and they put me through to another automated system.
This time I had enough. Virgin was on standby.
I called to cancel. Would you believe it, an IT support person was able to talk me through set up.
Each device had to be restarted to reconnect to WiFi, and now seems ok ?
All this cost me time and money, not to mention stress.
Why was it not explained that I should restart devices on upgrade, then most of this could have been avoided ?
After this, I will be keeping a close watch on the system to ensure it is as good as promised.
siphosethu-TT
Message 13 of 14
Hi there @Theshed, I'll need you contact our full fibre team so they can have the issue looked into for you.
03451720074
Opening Hours:
