Eero 6- 5Ghz not working on any device
ClaudiaP8
Message 20 of 20
Hi All,
I have had Fibre 150 since May 2023, with no issues. However the past two weeks all my devices especially work laptop and phone cannot connect to the wifi. TalkTalk sent a new Eero 6 to see if that would fix the problem however the issue still persists. The only way I can connect to any wifi is by manually pausing 5ghz and switching to 2.4ghz on the eero app which it only allows you to do at 10mins at a time.
I have read previous threads about the Eero's 5ghz channels being too high, but this is a problem thats has only just happen after working for 10 months fine.
is there any solution to this?
19 REPLIES 19
Message 1 of 20
Hi Claudia,
How are you getting on, is everything still OK?
Message 2 of 20
Hi again,
No problem. I'll check back in at the end of the week just to make sure that everything is still ok.
Michelle 🙂
Message 3 of 20
Hi Michelle,
Thanks for this, I've reset and now the 5ghz channel is on 42.
thank you for your help.
Claudia
Message 4 of 20
Hi Claudia,
Could you retest again please as this should now be resolved.
Message 5 of 20
I'm really sorry to hear this. I've contacted the team again and asked them to take another look and I will post back again as soon as I know more.
Message 6 of 20
Hi Michelle,
It has been perfect over the week however this morning my devices have been dropping connection again, I have checked my radio analytics and it has reverted back to channel 155. Is this not a permanent fix?
Claudia
Message 7 of 20
Hi Claudia,
How has your connection been over the last few days?
Message 8 of 20
Hi Claudia,
I'm sorry for the delay and thanks for the update. Are your devices now able to connect ok since this change?
Message 9 of 20
I have just checked my analytics this morning and the channel has changed to 58 and 52
Claudia
Message 10 of 20
Hi Michelle,
Is there any updates as I still have no internet on my major devices.
Claudia
Message 11 of 20
Morning Claudia,
Apologies, the devices manager has confirmed that it has been escalated and I'm just waiting for the fix to be applied. I'm hoping that I'll know more today at some point.
Message 12 of 20
Hi Michelle,
My radio analytics is still showing channel 155 but the control channel is now 149, but internet is still struggling on my main devices.
Claudia
Message 13 of 20
Hi Claudia,
I've chased the team for an update on this now.
Message 14 of 20
Morning Claudia,
No update as yet. If I don't hear anymore by the end of today then I will chase the team for an update.
Message 15 of 20
I've escalated this over to our Devices Manager now and have asked them to apply the fix. I will post back here to confirm once this has been applied.
Message 16 of 20
Thanks for that Keith- Will do!
Message 17 of 20
Hi @ClaudiaP8
Yes, those are the problem channels. I'll ask TalkTalk to apply the fix for this to your Eero.
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if you can, please include the serial number from your ONT in the Private Notes section. Please also try to include an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:-
Message 18 of 20
Hi Keith,
Thanks for coming back to me, the radio analytics says Channel 155 with a control channel of 153.
Claudia
Message 19 of 20
There is a known problem where the Eero does not stop working on its 5GHz band, but it starts using a channel that is not supported on the majority of devices. Please can you check in the Eero app under Radio Analytics and tell me what channel it is using in the 5GHz band?
