Eero can't connect to external IP address
jaw38
Message 24 of 24
I had fttp installed 30th October '23. No problems with the router supplied, fttp is great.
I have recently taken out a new contract on 5th March. I was sent the eero 6 router. The eero pairs with the app on my mobile. The ethernet cable is detected, however, it cannot find an external IP address.
I spent a frustrating 90 minutes online last night, with fibre technical support. The agent eventually stated he'd made firmware updates on my package. I was told to power down the ONT and the eero router for 20 minutes, after which all would be fixed. He then closed the chat as the problem was 'resolved' It was not and the same issue was still present after the obligatory 20 minute power down.
I can still use the original router supplied and my fibre connection is great. Are there any fixes for the eero?Is it worth sorting? I'm loathe to dedicate any more time to 'fixing' the issues.
23 REPLIES 23
Message 21 of 24
Thank you. Can I just confirm, are you using the Wifi Hub router at the moment? We'll need to make a change to the line profile for the eero to connect. When would be the best time to do this as the connection will stop working for a short period?
jaw38
Message 22 of 24
Evening, Michelle
I've updated my profile.
Message 23 of 24
  • Name
  • Telephone number
  • Alternative contact number
