5 hours ago
Is it possible to connect the eero to my router using spare telephone wall ports? That is, can I use a cable from the router to a telephone wall socket and then place the eero in another room and then connect it to another wall socket using another cable?
4 hours ago
The eero needs to be connected directly, vai an Ethernet cable, to the Full Fibre ONT, not an existing router connected to a phone line.
4 hours ago
Hi Keith and thank you. Is it possible I have connected my eero incorrectly? I’ve plugged it into the back of my router
4 hours ago
The eero 6 or pro 6 is a router for full fibre & should connect directly to an ONT.
