Eero router does not have discovery/secure plus
LouH81
Visitor
Message 13 of 13
We have full fibre with the eero 6 router, however we don't have access to the secure plus/discovery area which means we cannot change things like the ad blocker. Can this please be added to our account.
12 REPLIES 12
Message 1 of 13
Have uninstalled and reinstalled the app, no change to software.
Message 2 of 13
Hmm, the latest software version I have is v7.7.5-15, so you do seem to be behind. A pain it may be, but try uninstalling and reinstalling the eero app.
Message 3 of 13
Thanks,
All up to date as far as I can see.
Message 4 of 13
Can you click on settings and confirm you have no updates pending please?
If you do can you manually update. If it initially says up to date when attempting the update, click back and try again.
Message 5 of 13
Yes it was supplied by TalkTalk when we upgraded to full fibre.
Message 6 of 13
OK, it is usually pre-installed with TalkTalk's own variant of the secure provisions. Something seems to have gone amiss here, so the support will look into this for you. Unfortunately they won't be back online intil Monday now
Can you just confirm the the eero was supplied by TalkTalk?
Message 7 of 13
I still don't have that option if I minimise profiles. I think it needs to be enabled by talk talk.
Message 8 of 13
@fr8ys
For info, the app is the same regardless of model.
Message 9 of 13
Can you not scroll down?
Is it a TalkTalk supplied Eero? Is it a Pro?
I don't know if the app differs when its a pro but thought they were the same.
Message 10 of 13
Minimise the Profiles section, or scroll down, it should be there.
LouH81
Visitor
Message 11 of 13
We don't have that option in the eero app at all, certainly not on the homepage. I've attached a screen shot of what I can see.
Message 12 of 13
On the home page of the Eero app is Security and Privacy.
Under this is Advanced Security where you will find Ad Blocking etc.
The TalkTalk app is configured differently to the standard Eero.
