Wireless after fibre upgrade cannot connect to the laptops
fskaramagkas
Message 38 of 38
Hi @KeithFrench
Following up on the WIFI issues and all the information I gave on the previous chat.
We have a WIFI connection problem.
The laptops especially do not connect at all to the WIFI. The mobile phones and TV are fine , the tablet is dropping out but the laptops do not connect with WIFI. I  have to use an ethernet cable which works fine. Upgrade to full fibre on the 12th of March. The problem appeared and got worse the last 3 days.
Proximity to the router does not seem to be relevant.
Thank you
SKARAMAGKAS FILIPPOS
37 REPLIES 37
Message 1 of 38
Hi @fskaramagkas
I've ordered the WIFI booster, please allow 24-48hrs for this to arrive.
Let us know how the connection compares with the booster.
Message 2 of 38
Hi @Karl-TalkTalk ,
I have updated my profile with telephone and name.
Thank you
Message 3 of 38
Hi @fskaramagkas
Can you please update your Community Profile to include your
  • Name
  • TalkTalk Telephone number or Account number
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
Do not post any personal information, account numbers or phone numbers publicly.
Message 4 of 38
No problem, I have escalated it to TalkTalk, requesting this for you. Hopefully, they will pick it up on Monday now & offer it to you. If you get any problems with the F266, then I can help with all aspects of it. Try to make sure that you locate it roughly halfway between the router & the era of poor reception.
Message 5 of 38
Thank you
Message 6 of 38
The signal levels in that snapshot from your Sagemcom are very weak at that point. Let me see if TalkTalk can supply you with the FAST266 WiFi booster, which, when connected to your router, gives you a mesh network.
Message 7 of 38
Thanks @fskaramagkas
I do appreciate the summary, this week has been exceptionally busy for me. I will try & have a quick look later this afternoon.
Message 8 of 38
Hi @KeithFrench ,
The password for the zip file I just sent is again XXXXXX.
Thank you.
Philip
fskaramagkas
Message 9 of 38
Hi @KeithFrench ,
Please find a Wifi scanner test for upstairs.
There is a competing SSID PLUSNET-65C9C3 at 2.412 GHZ  active upstairs.
Please have a look .
Downstairs dropping of the Wifi happens there too but the competing SSID is PLUSNET-3QC2XK at 2.462GHz.  Frequency not so close.
I am only trying to give you a summary as I know you are dealing with many problems at the same time.
Thank you
Message 10 of 38
Hi @fskaramagkas
Its instability in this case might be because it is connected to the 2.4GHz band. When I looked before, I could see no evidence of WiFi interference, but if you want to do the diagnostics again, I will willingly look again.
Message 11 of 38
@Billx
This is not your thread.
Billx
Message 12 of 38
Hi, @KeithFrench ,
Is there an actual reset to reset the WiFi adapter in Windows? I can't find it. Or is it called something else?
Thanks,
Bill
Message 13 of 38
Hi @KeithFrench,
Taking on and off the ethernet cable starts the WIfi . Usually it fails after a short while but for the time being it is holding up. it dropped but then after a minute of authentication it reconnected.  Also the Wifi setting is to  WAP2. Please see attached an image of the Wifi settings.
Oops it dropped again as I was writing.
It does not seem to be solved.
For the settings Window It only allows to bring it down.
Phiip
Thank you for the help
Message 14 of 38
It is showing Not Fixed in the Issues Found section, but you have not expanded it, so I don't know what it is showing. However, your last screenshot is showing you as connected.
fskaramagkas
Message 15 of 38
Hi @KeithFrench ,
I reset it but it did not solve it. Please have a look at the attached screenshot with the WIFI information in case you can instruct me anything else for the laptops.
Message 16 of 38
Sorry, my mistake, you have the Sagemcom. I am dealing with a lot of concurrent complex issues & most have been on eeros. The error I can see in the WLAN Report points to an issue with security. Can you try resetting your WiFi adapter in the laptop back to default?
Message 17 of 38
I have not got an eero. The laptop that does not work is in the same room as the router. Still does not connect to WIFI.
The WIFI scanner I run from tah very laptop which does not work. I was connected via ethernet on the laptop at the time.
Message 18 of 38
Hi @fskaramagkas
The laptop is unable to establish the security mode with the eero. In the eero app, what is WPA3 set to:-
Settings > Network Settings > Wireless > WPA3
If set to On & the WiFi adapter in the laptop does support it, it should still be able to use WPA2. However, it might be worthwhile disabling it, to see if that improves your connection attempt.
Message 19 of 38
Thanks for these files. I will try to look at them this afternoon.
When it comes to addressing the poor wifi coverage, please get me another snapshot etc from Wi-Fi scanner near to each device experiencing this issue.
Message 20 of 38
Hi @KeithFrench ,
Please find enclosed the netsh wlan zip file. I ll send the passwd in a private message.
Just to provide somemore information if it is mpre useful. The devices drop out all the time. Two stopped connecting to the WIFI at all. They only worked for a week after the Cityfibre was installed and then the problems started. They work fine on the ethernet. One third laptop connects for a day on and off.
The TVS suprisingly work all the time, the tablet and mobile devices drop out and reconnect.
The problem is only on the WIFI . I run the report about midday. If you need me to run the reports some other time please let me know.
Dropping out seems to be the same throughout the day. As you probably realise there 2 - 3 ethernet cables running through the house at the the moment.
Thank you
