Wireless after fibre upgrade cannot connect to the laptops
fskaramagkas
Message 29 of 29
Hi @KeithFrench
Following up on the WIFI issues and all the information I gave on the previous chat.
We have a WIFI connection problem.
The laptops especially do not connect at all to the WIFI. The mobile phones and TV are fine , the tablet is dropping out but the laptops do not connect with WIFI. I  have to use an ethernet cable which works fine. Upgrade to full fibre on the 12th of March. The problem appeared and got worse the last 3 days.
Proximity to the router does not seem to be relevant.
Thank you
28 REPLIES 28
fskaramagkas
Message 21 of 29
Hi @KeithFrench
What is a PM. Is it something in the community.talktalk
Message 22 of 29
Hi @fskaramagkas
Have you checked your PMs, I did send it on the 26th of March?
Message 23 of 29
Hi @KeithFrench ,
Sorry about the delay. I do not think you have sent me the guide about identifying the WIFI problem.
Thank you
Message 24 of 29
That's fine @fskaramagkas , please do it ideally where the laptops are & also, if different, where the tablet is.
Message 25 of 29
Very interesting,
I will do the work this afternoon and send you the information.
Thank you
Message 26 of 29
No @fskaramagkas don't bother with the HG633; that is a very old specification now.
Do not worry about interpreting the results; I will do that for you. I will send a PM to that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially, look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos, please, as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 27 of 29
Yes please , I would like the guide.
I also have the old router which did not have problems like that at all. A Huawei  HG633. I could try that but it does not have any VOIP.
Message 28 of 29
Hi @fskaramagkas
There could be two WiFi issues here:-
  1. The laptops not connecting
  2. WiFi reception issues.
Since you mention a tablet is dropping out, then I think the latter is the possible cause, as the signal might also be too poor for the laptops.
In other words, I will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
