19-11-2023 04:29 PM - edited 19-11-2023 07:39 PM
Hi, on Wednesday 15th November CityFibre installed a modem and eero 6 for Full Fibre 150. When doing the setup on the eero app, it fails at connecting to the internet, showing an issue where there is no external IP address. We have tested using an Ethernet cable straight from the modem to an Xbox and there is still no connection - stating it cannot connect to DHCP server. Restarted eero and modem multiple times with no luck. I have seen this problem solved for others by having their profile changed from ADSL to Fibre. Could someone take a look at this please?
Thanks,
Kath
on 22-11-2023 12:50 PM
I'm sorry for the delay. Can I just confirm, has an engineer been today?
on 21-11-2023 03:51 PM
Update: had an email come through detailing the direct debit which included an account number, so have now registered for My Account.
I have added the account number and phone number to the ‘private notes’ section of my profile. Could someone please use this to check the profile is set up correctly for Fibre?
on 21-11-2023 11:39 AM
Hi Michelle
Yes we had a phone call yesterday I believe from the Fault Escalation team. Had us doing the same tests we had been told to do almost a week ago by the eero helpline; going through the eero setup, restarting the eero, restarting the modem etc. Told us they would get in contact with CityFibre for them to check out the issues which, if I’m not mistaken, they have already done and told us it was all good on their end and set up properly. I’m inclined to believe them as all the times I have seen this issue on these forums the fault has been with TalkTalk not having the profile set up properly so no IP address is assigned.
Had an email come through claiming the service was now live (still not) however it did say to look out for an email about setting up ‘My Account.’ Will this email finally provide me with an account number I can put on my community profile so that the technicians on these forums can check the account is set up correctly for Fibre?
21-11-2023 09:54 AM - edited 21-11-2023 09:55 AM
I believe that our Faults Escalation Team have made contact. Please let us know how you get on.
on 20-11-2023 12:31 PM
I've raised this over to our Faults Escalation Team now and will post back as soon as I receive an update. It's possible that the team may also try and contact you directly.
on 20-11-2023 11:37 AM
Hi Michelle,
I have added the information I am able to, however:
I have added some details to the Private Notes section regarding the details which the Fibre 150 plan was bought under.
on 20-11-2023 08:08 AM
Good morning,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 19-11-2023 09:44 PM
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if you can, please include the serial number from your ONT in the Private Notes section. Please also try to include an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:-
