Eero stuck on channel 155, please can fix be applied?
Message 46 of 46
Hi Guys,
My eero is now stuck on channel 155, please can fix be applied?
My current firmware is V7.3.3.
45 REPLIES 45
Message 41 of 46
Thanks very much @Michelle-TalkTalk
Message 42 of 46
Thanks @KeithFrench  I've passed this over and will keep you updated 🙂
Message 43 of 46
Hi @Michelle-TalkTalk
Yes, I have a laptop with a WiFi 6 card that only works up to channel 128 (D-Link DWA X-1850). This is now stuck on the 2.4GHz band. It is not even picking up 802.11ax on the 2.4GHz band either. I did check with the Prime support & the eero 6 does support 802.11ax on both the 2.4 & 5GHz bands, as per the specification. It always used to do work at WiFi 6 on either band with the Sagemcom FAST 266 booster.
Message 44 of 46
Hi Keith,
Our Devices Manager has asked if any of your devices are experiencing issues on channel 155 please?
Message 45 of 46
Morning Keith,
I've passed this to our Devices Manager now and will keep you updated 🙂
