on 13-12-2023 06:38 AM
Recently joined TalkTalk 150, who provided eero6 router which provides excellent WiFi. But I have tried plugging in my Yale nano hub 1 into it, but it doesn't work. Also I have a Hive heating hub, so need at least two ethernet ports whilst the eero6 only has one spare. Tried a splitter, which works with the Hive, but not the Yale hub. Any suggestions ?
Yale do not have a WiFi connected hub, only a plug-in
on 13-12-2023 08:26 AM
Hi @Anonymous
Yes, the workaround is to set a non-TalkTalk DNS in the eero router.
To enable a custom DNS requires eero Secure features to be switched off.
Gondola Community Star 2017-2024
Like below to appreciate my post . . . Mark as solved Accept as Solution
on 13-12-2023 07:31 AM
Morning Rob,
Can I just confirm, what happens when you try to connect the wired Yale device? Do you receive any error messages please?
@Gondola - have you ever come across this before?
