Epson ET-2750 printer keeps losing connection to WiFi Hub 2
Josephiah
Message 15 of 15
Since moving to our full fibre several months back, our printer has never quite behaved properly with the supplied TalkTalk WiFi Hub 2 (firmware version SG4K100174).  When powered on, it connects wirelessly to an automatically-assigned IP address and appears to work fine, staying available and connected for a number of hours (not sure how long).  However, if I try to print something later (say next day), none of our devices can find the printer until and unless I switch the printer off and on again. (It can only connect on the 2.4GHz band, but it's in the same room as the Hub, and never seems to have a problem connecting when restarted.)
It feels to me like this is a networking/IP assignation issue - I had a look through the Hub settings to see if I could set a reserved IP address to see if that would help, but can't see a way to do this.
So, does this seem like a likely cause of the disconnection issue?
How can I diagnose this more precisely?
How can I set a reserved IP address?
Thanks,
Jo
14 REPLIES 14
Message 1 of 15
If you can log into the router, setting a DHCP-reserved IP address has always been possible.
Message 2 of 15
Thanks Chris. Did you also set the printer to a reserved IP address? (I previously did not seem to have access to these settings.)
Cheers,
Jo
Message 3 of 15
OK, I've switched wifi optimisation off now
Message 4 of 15
OK thanks Jo, I'll try again now
Message 5 of 15
Hi Chris,
It is now back on, after being off for half an hour.
Thanks,
Jo
Message 6 of 15
Well, I'm not certain, but to my uninformed mind it doesn't feel like a good fit to the symptoms. If you think you have something that might help (or rule out that that is the source of the problem), then feel free to pass it over.
Message 7 of 15
Could you switch your router off and leave it off for at least 30 minutes, then switch back on and let me know when you've done this
Message 8 of 15
Hi Chris, yes it is. Anything you want me to do that night help with this?
Message 9 of 15
Hi @Josephiah
Fair enough, if you are so sure it is not a WiFi interference problem (even though this can easily cause delays), then there is no point in me sending you my guide.
Message 10 of 15
Hi Jo,
Is your router currently switched on and connected as I can't communicate with your router at the moment
Message 11 of 15
Hi Michelle,
That info has now been added.
Thanks,
Jo
Message 12 of 15
Hi Jo,
  • Name
  • Telephone number
  • Alternative contact number
Message 13 of 15
Hi @KeithFrench, thanks for the reply.
I don't think it's an interference or range issue; it feels more like a timeout kind of behaviour.
No, I haven't previously had Wi-Fi optimisation disabled - please go ahead.
Likewise, please go ahead and send out the guide you mention.
Thanks,
Jo
Message 14 of 15
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
