on 05-09-2023 12:33 PM
I recently subscribed to Full Fibre 65, and while the download speeds have been great, I'm having some serious issues with my upload speed. It's been frustrating, especially since I need a reliable upload connection for work and other activities. Is anyone else facing a similar problem with Full Fibre 65?
on 08-09-2023 08:02 AM
Hi AmeliaCatherine
Do you still need help with this?
on 06-09-2023 07:17 AM
Hi AmeliaCatherine
What speed are you receiving when running a speed test?
Have you tried powering down the router for a full 30 minutes?
05-09-2023 12:49 PM - edited 05-09-2023 12:54 PM
2. If you log onto the router what are the download & upload speeds quoted there (normally in the initial dashboard area)? If however, you have full fibre the way to check the speed is different. Please can you connect an Ethernet (wired) device such as a PC/laptop directly to the ONT in place of the router. Then do a normal speed test there.
3. If you have any wired connections, are they affected in the same way as wireless ones?
