Fibre router wifi dropping
Judyaughton
Message 15 of 15
My wifi keeps dropping and then reconnects. The light stays white on the router when this happens. Can you turn off wifi optimization as have seen on here that has fixed the issue for some. Router is a sagecom fast 5464-2.t4. It has been rebooted and factory reset.
14 REPLIES 14
Message 1 of 15
Hi @Judyaughton
Thanks for your reply. Yes you can 🙂
Message 2 of 15
Yes, it is exactly the same router model.
Judyaughton
Message 3 of 15
Yes thats fine. Am amsuming i can plug my phone into it?
Message 4 of 15
Hi @Judyaughton
Thanks for the Private Message.
I can send a WIFI hub 2 router, are you happy for me to go ahead and arrange this?
Message 5 of 15
Hi @Judyaughton
Please can you send me a Private Message to confirm the name on the account, I can then check which router can be sent out.
Judyaughton
Message 6 of 15
Hi Debbie
have added name and number to profile. Please send a replacement router.  Will it be a like for like or will i get a eero router as advertised for full fibre at the top of this page?
Message 7 of 15
Thanks @KeithFrench
Hi @Judyaughton
Would you like me to send a replacement router? Please can you add your name and TalkTalk landline number to your Community Profile.
Message 8 of 15
OK, maybe the router is faulty. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
Judyaughton
Message 9 of 15
Hi Keith
Its not signal strenght as it happens when sitting next to the router. The device has full signal when the issue occurs.
Message 10 of 15
Hi @Judyaughton
This may well be the case, but I really need to see the results as it could be a signal strength issue in certain parts of your property. Then based on what I see, I will make recommendations to TalkTalk on your behalf. Of course, I will move this thread to the Full Fibre board.
Message 11 of 15
Hi @Judyaughton
No problem at all.
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Judyaughton
Message 12 of 15
Hi @KeithFrench
Can you send me the guide please.
Message 13 of 15
Hi @Judyaughton
@Gliwmaeden2 has asked me to help you which will be a pleasure.
Gliwmaeden2
Message 14 of 15
It's not possible to switch off WiFi optimisation these days, @Judyaughton  - a business decision.
@KeithFrench may be able to advise you.
