Fibre router
Mrobjoo
Message 50 of 50
I have just ordered full fibre 150 and the email I received said that I have the correct equipment already , I have the hg633 , is this router suitable for full fibre
49 REPLIES 49
Message 1 of 50
I have checked on your account and there is no order for the router, kindly call in again and the full fibre team will assist further, thanks.
Message 2 of 50
I contacted them 2 weeks ago and they said they would send a router out , but they never did
Message 3 of 50
Hi there, I am sorry for this if the current router you have is not compatible a new one should be provided.
Please use the below details to contact full fibre and they will assist you further with this, thanks.
Contact Number: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
WEB MESSAGING - Mon-Fri: 8am-9pm; Sat: 8am-7pm; Sun: 9am-7pm
Mrobjoo
Message 4 of 50
So Talktalk did not send out a router , and they turned up today to install full fibre , but. Could not do it because I have an incompatible router , please please can some body sort this out , taken a DaY off work for this to be done , thank you
Message 5 of 50
Thankfully after having to phone talktalk it is now all sorted and they are sending a new router out that will be suitable , I believe it's the Hub 2 .thank you everyone for your help and assistance . Let's just hope I do receive the new router ,
Again thank you .
Message 6 of 50
"And the assistant who helped you,, sent you the above automatic message yesterday at 1:43 PM, and included in the message was the following snippet: "Great news you already have the right WIFI Hub for full fibre".
I believe that is a lazy and false statement"
I couldn't agree more Billx you would think with the bad reputation phone support and to a lesser degree online chat has that the staff would at least know the basics how can anyone in a "Support" role not know something so basic?
Message 7 of 50
@Mrobjoo, I have removed the displayed image of your router and password  - should you ever need to reset your router to factory settings, that password will again take over from what you made up.
It's bad practice to ever display such information in the public thread.
Billx
Message 8 of 50
Hi, @Mrobjoo
So, you ordered it 2 days ago.
I believe that is a lazy and false statement.
The current router, HG633 is not suitable for any Full Fibre TalkTalk package, which is what you ordered.
The grey socket at the back of that router is suitable only for part-Fibre TalkTalk packages, which  TalkTalk often calls just 'Fibre packages'. The socket, which is required for a Full Fibre package is a WAN socket, usually coloured red, and which is not available in the current router.
As  listed by @ DJI_MINI_3 above, the available TalkTalk routers are:
Any of those would be OK, except the HG633.
There is also an additional suitable router not listed in the list, the TalkTalk WIFI Hub 2, which can additionally handle VOIP, if you did need it.
As far as I can see, if none of the staff here, can deal with above, you should contact the phone or chat service again.
Bill
Message 9 of 50
Not not installed , which is why I am trying to sort the router before it's unstalled
Message 10 of 50
@Mrobjoo
Just to be clear, you originally ordered the upgrade on 24 May you said earlier, so it cannot yet have been installed, surely?
Message 11 of 50
I take it you mean the upgrade
Message 12 of 50
May 24th
Message 13 of 50
Just to confirm, when did that take place?
-Fez.
Message 14 of 50
Thank you , but they have been changed
DrStrange
Message 15 of 50
@Mrobjoo, You might want to black out your wi-fi network name and password and the login name and password for the router's interface GUI (router settings) for security reasons, unless you have changed these details to something else after you got the router.
Message 16 of 50
 this is my current router
Message 17 of 50
Message 18 of 50
Please send a screenshot of the email advising you that the equipment that you already have is correct
Message 19 of 50
Hi please can you confirm If I will be sent a suitable router , thank you
DrStrange
Message 20 of 50
@Anonymous, Thanks for your reply. Yes, I considered this. But by using a Sagemcom Fast 5464 router that cost £20 instead of a switch, I get rid of the Eero 6 and the Grandstream DVA. I value aesthetics more than £ when the £ is of low value.
Sorry for introducing extraneous info causing thread to go off topic.
