Fibre500 Upgrade
Markysuzy
Message 21 of 21
Hoping someone can help.
Upgraded from Fibre65 to Fibre500 on Monday 6 Feb. I already had Full Fibre connection into my house.
I received new eero router and Openreach installed this router on Monday.
My question is when should I start to see increase in speed.
I am still getting same speed as prior to upgrade.  No change.
20 REPLIES 20
Message 1 of 21
Just a quick update to let you know that this has been raised to BT Openreach for investigation
Message 2 of 21
Message 3 of 21
OK
Thank you
Message 4 of 21
Thanks. I'll pass this to our Future Fibre team and ask them to take a look. I'll let you know when I receive an update or they may contact you directly
Message 5 of 21
Yes
had Fibre65 from December 2021
Message 6 of 21
And just to confirm, you had Future Fibre 65 before upgrading to Future Fibre 500?
Message 7 of 21
Yes
currently connected to internet
Message 8 of 21
OK thanks. Could you just confirm that you currently have an Internet connection as our system isn't showing that your router is connected
Message 9 of 21
Yes I connected my laptop directly to ONT and ran a Speedtest from internet.
Same speed being recorded.
Message 10 of 21
Just to confirm, you've tried connecting a device directly to the ONT bypassing the router and the speed was the same?
Message 11 of 21
Poweref down both router and ONT for 40 mins tonight
Still no change in speed at ONT.
Message 12 of 21
Message 13 of 21
OK
Will do that later tonight and come back to you
Message 14 of 21
Thanks. It does look as though the speed has been increased. Could you switch the Eero and ONT off for 30 minutes then switch back on and retest - please let us know if your speed improves
Message 15 of 21
Added account number and FTTP number also
thanks
Message 16 of 21
Thanks but could you also please add your order number or account number to the private notes section of your Community Profile
Message 17 of 21
Thanks for coming back to me.
I have updated information as requested.
Message 18 of 21
Hi Markysuzy,
  • Name
  • Telephone number
  • Alternative contact number
Message 19 of 21
I did power down both ONT and eero yesterday.
Speed I am seeing at ONT is 75 download and 22 upload
This is exactly as it was last week before I had upgrade.
Message 20 of 21
What speeds are you seeing? Have you tried powering down the ONT and the eero and then retested the speeds again? What speeds do you see if you connect directly at the ONT?
